K75S / 1988 Bringing back to life
I've measure my valve clearences, and they seems to be okayish:
inlet (upper): 0.2, 0.2, 0.18 mm
exhaust (bottom): 0.25, 0.33, 0.25 mm
the only one out of spec is in the middle exhaust, but watching video from Chris on youtube, he says that "loose is okay" so I'm not sure if it worth to adjust.
I've took out 2 shims:
- upper right is 2.6mm
- bottom middle is 2.5mm
anyone knows if those are standard shim sizes, meaning they're like not being replaced?
Nomad,
BMW makes shims from 2.00mm to 3.00mm in .05mm increments. They are about $10 each.
If I was planning on keeping the bike, I would be tempted to change the shims on #1 and #3 exhaust to .05mm thinner.
That will loosen them from .25mm to .30mm. Exhaust valves always tighten over time, so if you loosen them to the high side of spec. (.30mm) now, it will be longer before they become too tight. You are currently at the tight end of spec. And don’t know how long it will be before you are under spec.
Your intakes are fine, as these don’t tend to move very much over time.
One thing you must be aware of: the valve cover bolts have a flange on the thread end that BOTTOMS OUT on the head and then gets snugged to 6.5 ft/lb. Any tighter and it will strip out the threads in the head! The only torque wrench that is accurate at that low torque is an INCH/lb ( usually 1/4” drive) torque wrench). Use 78 in/lb to achieve 6.5 ft/lb. If you don’t have one, borrow one or get one from Harbor freight (less than $20).
Since the bolts bottom out, the actual clamping force on the valve cover gasket is provided by the rubber bushing around the valve cover bolts. Over time, the bushing harden and loose their resiliency thereby loosing their clamping force. Tightening the bolts further will not increase the pressure on the gasket and you risk stripping out the head (NOT GOOD).
When removing the valve cover, you should plan on replacing the 10 bushings ($1 ea.) by having them on hand. If the old ones are still soft and pliable and not permanently flattened, you may decide to reuse them, but you will need to replace them next time. On a new to me bike, I always replace them the first time. Cut the old bushings off with wire cutters, slip the new ones on. Valve cover gaskets are usually good for 2-3 valve checks or several years before needing replacement. Do not use sealer except a SMALL dab on each edge of the rubber half moons at the rear of the head and the two junctions between the timing cover and the head.
:dance :dance :dance
Hi all, wanted to report back on this. Work I've done lately:
- throttle body manifolds replaced
- injectors cleaned & synced
- tank cleaned, fuel pump, filter & subversive fuel line replaced (except for black one filter - to tank)
- valve adjustment, now measured as:
up (inlet): 0.2 0.2 0.15 (didn't change shims)
down (outlet): 0.33, 0.33, 0.35 (changed shims 1 & 3)
Finally bike starts and runs great.
I have to say, I should've listened better and start with cleaning tank first and replacing filter and maybe pump, as even though it didn't look dirty what came out was like a jelly which was probably the biggest reason why bike didn't run well, but also probably clogged up fuel system.
Btw I've used Quantum fuel pump & filter, also kit included corrugated plastic fuel line. I wonder if you have to use clamps with it? Existing clamps are too big, and kit didn't had any, it seems to be pretty snug fit.
Nomad,
Great to hear that it is running properly!
Yes, you need clamps on those hoses! Either the proper sized fuel hose clamp (like the one in your photo) available from your dealer or possibly auto parts store,or the proper sized Oetiker clamp (available from Quantum among other places). Oetiker clamps require a special tool to crimp them and they require cutting to remove them.
I would use the BMW style fuel hose clamp. Do not use standard gear hose clamps as they will distort the hose and cause leaks or premature hose failure.
Rode this beauty first time today. It's so smooth compared to r nine t.
I'm more convinced to restore it now, maybe repaint, replace ignition which was vandalized and find matching side cases.
Thank you @98lee, your advices were invaluable.
Question: this is cable to instrument cluster has a grommet but I haven't found where it should be attached:
Nomad,
On the left side of the black center cover there is a flat pad that allows you to zip-tie the harness to it. Put flat of bushing against flat pad.
PM sent.
