Looking for some advice about an oil leak on my 2004 K1200gt. The leak is on the left side of the engine. It appears to be coming from somewhere high on the engine and running down the left side just behind the 4th cylinder and exhaust. Quite hard to see. At first I thought it might be the dreaded clutch oil seal leak, but (so far at least) there are no tell-tale leaks around the bell housing seam on the right-hand side or the bottom. Don't know what's up there that could leak oil. Someone on the K-bikes site suggested the oil breather line might be leaking? The leak is bad enough that it eventually runs down and drips oil into the belly pan after a long (100 mile +) ride. I've tried to take a photo of it as best I could (sorry the photo is sideways!)
