mbellantone
AirandOil In NJ
Hey kids, just replaced the new needle bearing and race bolt on the gear shift on my '84 R80RT. Yes, this is the type that I only seem to have where you need to take off the left foot peg which has the shift lever bolted to it, (from the engine side). I say that I'm the only one who seems to have this is because no matter what manual or fische I go to they always show the shifter bolting on from the outside.
Question is, I did not notice any bushing, ringwasher or the like that took up any lateral freeplay between the shifter and the bracket it's bolted to on the foot peg and when tightened to the point where it will go no more there is still a slight bit of lateral movement between the peg and the shifter.
I do not like this.
Considering that the bearing I replaced was horrifically worn and I don't remember my last airhead from 15 years ago, should this play be there? Like I said, i have no other pictoral reference so I can't tell if it's missing a VERY thin washer or not to take up this extra play..
thanks in advance for your help.
Michael
I do not like this.
Michael
