Hello. Anyone had any experience with removing a botched Red Koat liner and remnants of original BMW factory liner from 20 year old tank. The Red Koat liner was applied on top of the failing BMW liner. I have done some research and plan to use acetone to remove the Red Koat liner and Vinegar to remove the BMW factory liner. Just don't know the best process for this. Do you fill up the 5 + gallon tank with the acetone or just use like a gallon to swish it around inside the tank? Also, how long does it take for the acetone to do the trick and once the Red Koat liner is out, what is the next step as far as washing out the tank prior to the vinegar going in?
