I have a 2007 Hexhead RT that chugs and stalls when fuel in tank reaches about 1/3 full. Has happened 3 times now, and always at the same fuel level mark. Refilling the tank seems to make it go away.
I've already replaced the FPC with the new black powder coated one, and checked venting lines, added Heet to the tank in the event there was water, ran Techron through about 1000 miles before problem surfaced, ran GS911 diagnostics (no fault codes), inspected plugs, and since I was at it, gave the bike a TB sync, valve adjust, and reset on stepper motors.
One other important thing-the fuel pump was replaced by dealer 13 months ago under the leaky flange recall.
My hunch, and I'm not a mechanic, just read a lot on here, is that the fuel pump or in tank hose is somehow fuel level dependent and I am about to pull the pump. Would a crack or pinhole in that plastic yellow flex line somehow draw air instead of fuel when it goes from being submerged in fuel to being in the air?
I have an appointment to bring it to dealer next week, but I think since BMW bought the last fuel pump I may be stuck with paying for this one, so I am appealing to the experience of others for tips on removing and diagnosing the fuel pump for a possible fix.
