mneblett
#32806
Hi, all -- next Q in my 1988 R100RT rebuild --
I've now extracted this:
from this:
I would like to touch up the main frame paint in a number of areas. My first thought is to do small touch-up re-spraying, rather than having to bite the bullet and fully strip the frame (wiring, forks/steering head, RT bracket headlight, brake line, etc.). On the other hand, I already know I need to strip out the steering head to inspect and re-pack the steering head bearings, so I will be maybe 50% of the rest of the way to a full frame strip.
Advice? Comments? Rattle can or full strip and send out for a pro re-spray (or even powder coating)?
Recognizing that most of the frame will be hidden from view by the RT fairing, my number #1 priority is corrosion protection.
I'm thinking (at least as of 10:55 PM on 10/31!) of cleaning, prepping and spraying the entire lower 3/4 of the frame (i.e., the "U"-shaped double tubes below the backbone) and calling it a day. There are no scratches/bad paint areas with the backbone or the steering head, so this approach would avoid a fair amount of what seems like unnecessary work removing the wiring, etc.
If I go with painting the lower 3/4, what I need more than anything else is your paint recommentations -- your suggestions?
Thanks,
Mark Neblett
Fairfax, VA
A gaggle of boxers
from this:
Thanks,
Mark Neblett
Fairfax, VA
A gaggle of boxers
