Bike is a 2020 R1250GS. I was subject to the drive shaft recall and my bike failed the test, so the dealer replaced the final drive shaft. I was finally able to pick up the bike but I discovered after returning from dealer (~2 hours away) that they have overlooked securing the front drive shaft boot properly. Some people call it a gusset.
I can access the outer side easily to grease and replace but I can't access the other inner side with anything other than the very tips of my fingers from below - so I can't close it properly. Is there an easy way to do this without extensive disassembly? The easiest access to that side of the boot seems to be behind the battery box. Do you remove the battery box? Are there are other things to watch for here? Thanks all!
