MonoRT
MonoRT
I've got an '85 R80RT with twin disks that are connected to each other by a hard line that arches up under the fork brace and one flex line to the fairing.
The bike has about 265K on it now. A couple weeks back, I got a screw in my front tire, plugged it and set up with my dealer to get a new tire installed. Before the tire change, the front wheel spun pretty freely (I kept checking the plug) and after the new tire was installed, I noticed (not while riding, but just spinning the wheel by hand to get the valve into the right spot to check the air pressure) that there is a fair amount of drag - I'm not all that strong, but a good push on the front wheel only gets about one third of a rotation. The drag is even, no grab and release action.
When I stop after a ride, there is a fair amount of resistance to being spun by hand and both disks are uncomfortably hot (to try and hold on to), but not sizzling hot and, according to my calibrated fingers, there's no discernible difference in heat between the two disks. Even when everything has cooled down, the brake drag remains. The brake lever returns to it's stop when I release it and the reservoir is filled to about 5mm below the MAX line.
There are a bunch of possible culprits here and I wanted to see what the group might suggest.
The flexible brake lines are stainless steel from San Jose BMW and they have at least 240K on them. The front calipers are supposed to be removed when the front wheel is removed, but I can't tell if that was done or not. That might have impacted the lower flex line, but there is no visible crease or crimp. I know that SnowBum was written about invisible failures inside those SS Teflon lined brake lines and that might be a problem...
I last rebuilt the calipers at about the 100K mark, so they might be overdue for a rebuild - I don't see any tears in the dust boots and I don't see any fluid weeping or drips.
I rebuilt the master cylinder a couple of years back and had to 'hone' the bore with a super fine ScotchBrite patch, a shotgun cleaning rod and a drill motor because the new piston hung up on the white oxide that had formed tiny spots in the bore. In that case, the lever would not return to it's stop unless I pushed it back with my fingers. At this point, I'm not seeing any fluid weeping or dripping around the master cylinder.
New BMW brake pads went in a couple of months ago.
What do you all think?
