I was having trouble locating the Diagnostic port on my 2016 R1200. I wanted to connect my GS-911, and the port was not in the same place as on my 2005 R1200 or my 2009 GS F800 (under the seat).
The online Haynes manual has a great color picture of the port itself, but they don't tell you where it is located. On the Right side of the bike as you're sitting on it, there is a small triangular panel that pops off to reveal the shock adjustments. It ain't that one.
Just to the front of that panel there is a larger triangular flat-black fairing panel that is attached by two T25 Torx fasteners at each corner, and a plastic pin pushed into a grommet above the cylinder head. Remove that panel and you'll see the Diagnostic port. You can access the battery there too.
