JDOCKERY132445
OldBMWMaster
$43.68 when I ordered just one 6 pack. When I changed the order to rwo 6 packs, the discount was not figured for the second. No problem. Ordered one and then logged into my wife's account for the other.
Paul, any comments on how this oil affects shifting quality over Advantec Ultimate? I am imagining it's the same on shifting and clutch behavior but just checking as the price is sure right on it. Also, have you ever done a Blackstone UOA on it and if so after how many miles? Thanks
Just ordered two times for one case on each order. Shipping time estimated to be 1 to 2 months. Thats OK, I still have a small supply.
Great find, Thanks
Castrol-Power-Racing-Synthetic-Motorcycle
tks, jason
Yep, and the spec for air/oil cooled camheads is 10W-40, but other than that...
If you check your tracking info it probably shows 1 or 2 weeks.
For me, I did notice a difference in shift quality, and not for the better.
I have a 2016 R1200GSW with the gear shift assist type transmission. I found this oil to have degraded the quality of shifting in my bike.
I have about 2100 miles on this oil and noticed a difference from almost the beginning. With this oil I have found neutral to be much harder to find. From neutral to first is much louder and more abrupt and shifts in the other gears not as smooth.
I personally won't be using this oil again and will drain it and change it early due to my dissatisfaction.
