typ181r90
Superkraut
It looks like the original Bosch starter in my R90/6 finally bit the dust. Seemingly out of nowhere the bike wouldn't start, it would crank really slowly and difficultly like it was a weak battery. I thought the 2-year old Odyssey may have been the issue and replaced it with the same results, then proceeded to check the ground, relay, and all connections which all seem fine. Figured I'd pull the starter since the next likely culprit would be the bushings and when I pulled it to investigate I noticed this wear/pitting on the bendix drive.
It doesn't look like EME has 8-tooth drives anymore, and since this isn't even related to the bushing issue I was trying to check in the first place, the costs of rebuilding may approach the costs of buying new. What do people generally recommend now as far and rebuilding or replacing? Oak just said in this month's airmail that Valeo starters are junk, the Enduralast is essentially a Taiwanese copy of the Valeo, and I've heard mix reviews of the Nippondenso starter.
Honestly, I'd rather just go with a rebuild from Motorrad Elektrik, but would like to hear some other people's experiences.
