tyme2sail@msn.com
Looking to add Tachometer, C has no tach signal wire available. The signal wire is sheilded to the coil, I was going to use a Scotchlok water resistent tap at the coil end of the wire at the connector. I need to know if the shield is incorporated into this wire or does it end under the cable insulation, where the 2 wire come out. I can't see where the shield is terminarted at the connection. The reason I ask this question, the signal wire is a little thicker than the power wire.
