slowrider60
ABS Rear Circuit Fault
I do not know how to proceed so I am hoping that someone can point me in the right direction.
I have an 02 R1150R with about 65k. I have owned this bike for about 7 years. It had 25k on the clock when I found it. She has been well cared for and has given me much enjoyment in return. I have done most everything myself except for the final drive that went around 40k.
I do the ABS flush myself and was last performed last year. At that time I broke a pin off the ABS connector and sent it out to Indiana for repair. I was glad I used Module Master. They were great. While the unit was there, they checked everything out and told me the unit was working fine. I have had NO issues with the unit since or with the bike until last week. I rode home from work on a Thur. with no issues. When i got on to go to work on Fri., i had an ABS fault. I determined it was with the rear brakes. If i pulled in the front brake i could hear the pump come on. When I put my foot down on the rear brake, there was nothing. I went through the basics, checked brake lights, fluid in the rear brake reservoir and checked the battery. All was well. I than took the tank off and checked both ABS reservoirs and both were full.
I pulled the rear ABS wheel sensor and wiped it clean. no change. I am wondering if there is anything else that I can do?
I appreciate any help offered.
Thanks,
Steve
Thanks,
Steve
