'93 K75s/ABS - Stumbling under acceleration after spark plug change.
lanceharrison
Greetings!
So, I changed out my spark plugs Bosch X5DC to Bosch X5DC last Saturday, and all seemed well: Fired up the engine and it sounded normal under stationary revving. Tried to meet my club for a ride the next morning, but had enough stumbling/halting issues under acceleration that I turned around and came home. No, I did not do a test ride post-maintenance, unfortunately, so I did not catch that issue earlier. :-/ The following are some notes regarding my thoughts on this issue.
Note 1: I did attempt to modify the gap on one plug, #1 cylinder: Did I damage it inadvertently? I used the coin-type gap tool I already had.
Note 2: I did -not- have my m/c cover on my bike during the rain late last week: The car port where I store my bike is open on two sides and it might have gotten wet while I was at work. Should I be thinking water in the gas tank, or stick with the plugs as the possible issue?
Note 3: I tightened the plugs down finger-tight, then gave a 1/4 turn with the plug tool. I tried to use my Pittsburgh PRO (Harbor Freight) inch-pound torque wrench, but I could not hear/feel the "click" like with my Kobalt (Lowe's) brand foot-pound torque wrench, so I backed it off and stuck with a 1/4 turn. Also, I did use copper anti-seize on the plug threads.
I am going to try swapping in the old spark plugs and see if that changes anything. If it does, then I assume it is plug related. If the issue persists, then I do have Iso-Heet on-hand to try if anyone thinks this might be water-in-the-tank related. I am concerned it might be an air leak in the system somewhere as mentioned in at least one other thread I was reading here in the forums (http://forums.bmwmoa.org/showthread...ut-am-I-looking-at-breather-issues-or-bad-HES)
Please offer any feedback. I look forward to hearing (reading) from you.
-Lance
UPDATE: "Original" plugs back in place
OK. Just replaced the "original" plugs that came with the bike. Bike fired up and revved "normally," i.e. like before I tinkered with it. Now for a test ride around the neighborhood.
-Lance
See if the screw on tips (wire end) of the plugs are tight.
Inspect the ceramic for any cracks.
Too much anti-seize?
:dance:dance:dance
My hunch is that one of the spark plug caps did not snap securely onto the plug - causing an erratic spark at one cylinder.
Plugs could be a red herring. Stumbling under acceleration also happens when you're low on gas and it moves away from the pump pick up as you goose it. Or a plugged gas filter.
UPDATE: Test ride successful!
OK. Just got back from the test ride. Neighborhood run was good, so I took it out to the freeway. Feels like it is running "normally," i.e. the same as it ran before I started tinkering. One thing I did differently was to tighten the plugs down finger tight with the spark plug wrench, then tighten it down with about a 1/2 turn using the lug-wrench over the plug wrench. I skipped the torque wrench this time. I believe the Clymer manual is the one that recommends to tighten down with that half-turn on the wrenches, then using a torque wrench for the final bit.
98lee: I checked the plug caps and they did not feel like they could be twisted off. I actually read a long thread regarding spark-plug caps that screw on at the "nipple" end of the plug (opposite the electrode-gap end, I assume) on Ted's www.k11og.org forum the last couple days (old thread). I did not know such a thing existed before reading that thread. The ceramic appears to be good on both the "old" and new plugs. I would have to use a good magnifying glass to see if I did anything damaging while trying to enlarge the electrode gap on the #1 cylinder new plug. I tried to make sure I kept the anti-seize on the threads only, and not on the electrodes. :)
PGlaves: I tried to ensure the wires were pushed back on tight when I reseated the wire caps: I used the pliers to hold onto the wire cap tabs when removing and reseating the caps. I did use "djverhult's" YouTube video here as a reference, along with the Clymer, Haynes & BMW K75 (c.1995) Owner's manuals during the work. It is still possible one wire was not fully reseated.
35634: I learned the gas issue the hard way last year riding to San Jose on Cinco De Mayo. :) (The flap in the gas cap was removed last year by my local BMW shop when they replaced the clutch and rear main seal.) I had a full tank of gas when I started out this past Sunday morning. Since there was no evidence of stumbling during this evening's ride, I am hopeful that the fuel filter will not be an issue anytime soon. *fingers-crossed*
Thank you all for your responses!
-Lance
P.S. I used just the BMW tool kit for tonight's wrenching.
