Hello new to the forum but did search for an answer. 2nd Fuel pump replace in 6 years (filter hoses and Pump) also took the injectors and had them cleaned for the first time. Problem the bike will not start, runs only as long as I spray starting fluid thru the air intake. tested the injectors but do not see any fuel coming out. when I turn the key to on I her the pump for 2 seconds, and when I try to start If I put my ear to the gas tank I could hear it engaging. Could I take the hose that comes out of the tank the high pressure one to see if gas comes out when I crank to see if is working, I do not have a pressure tester or the bike ill not start to test the pressure. I just want to test as much as possible before continuing to the pressure regulator in which I have to spit the bike apart to get to it.
