kentuvman
So, I thought I'd solved the problem causing Tina, my Red R65LS to die - I figured the problem was failure of the Hall Sensor in the bean can and ordered this part on Ebay:
http://www.ebay.com/itm/HALL-PICK-U...101S-HKZ121-/121173275830?hash=item1c367d74b6
This was my 2nd rebuild so I do have a spare can - the results were good - bike started easier and took some nice rides w/out incident.
But this season, the Tina has failed me twice. First time she started backfiring and symptomatic of an electrical problem - motor backfired, lost power and died, I started her up and rode her to work - then she wouldn't start so after disabling battery, removed front shield and thought perhaps the connection from bean can to where it plugs in was not secure enough but it was - bike started up and I've been riding her off and on w/out incident.
Today I went for a ride with a friend and she was running fantastic - after about 25 miles she started acting up again - took off the shield again and everything looked okay - started her up and rode another 3 miles and same thing . . . I'd turn on the ignition and the tach needle started moving on it's own w/out engine running which to me points to the Hall sensor - my friend got his truck and Tina made it home on 4 wheels.
Now I'm seriously trying to get to the bottom of this - I pulled tank and removed the heat sink unit - it seems to be the companion to the bean can, is that right? It has heat sink paste and everything looks good - I've gone through the wires & connections and believe connections are all good. I know it's electrical - bike runs awesome and plug colors are perfect.
Obviously something is wrong here - maybe time to buy the Motorrad kit? But before I spend the money wondering what else to check? I did test the coil, which was replaced (it's not the gray crack-0-matic). I pulled a plug, one at a time, switched on the ignition and moved the kill switch on and off and there is a spark on both so thinking coil is not the culprit.
Frustrating . . . thought I had this handled but I thought wrong.
Could it be that the component that's attaches to the heat sink unit needs replacing? Here's a link to one for sale on Ebay that's new Do these fail? I'm almost certain the bean can is golden.
http://www.ebay.com/itm/BMW-R80-R10...7-8-/251903082294?hash=item3aa697ff36&vxp=mtr
Mine's a Telefunken - looks to be OEM
What else should I be looking at? Maybe another bike?
