fordtech50
After I changed the oil on my bike- which was way overdue- I can no longer read the oil level on the sight glass. The sight glass interior seems to have a gold color to it now and is no longer clear. It's like the new oil coated the glass and stuck there or something. I don't think it's overfull because I changed it when it was fully hot and let it drain for a long time and added 4 qts. Book says capacity is 1.1 gallons us. You can shake the bike side to side but never see oil moving or sloshing inside the glass.
Has anyone run into this? The sight glass seems to be able to come out easy enough when I change the oil next time and My oil sensor is working as I get the check mark on the screen at idle, but I'd like to know if I'm using any oil and be able to see the level.
What the heck would cause the sight glass to do this just by changing the oil? Is this something common to happen? I feel like draining the oil just to see if the glass becomes clear again.
