mchad
I ordered a set of LED indicators and the LED tail light. MAX advised me I needed a "retrofit kit", which I ordered as well. To my pleasant surprise, the entire install took all of 20 minutes in total. The indicator kit included weatherproof plugs with wire tails and some crimps and heat shrink sleeves, which the instructions said I would need to splice into the existing wirng. However, I found that on my bike at least, the existing indicators used the same connectors as the new LED's do, so plug and play, 5 minutes a side. The tail did require a harness adapter, as the incandescent version has 3 blade connectors on the harness, and the LED uses a plug-in connector. Instead of the included splice kit, I used Ancor marine grade butt connectors, which have adhesive lined heat shrink sleeves. As bullet (and weather) proof as they come. All in all, easy as pie. Except for the need to get the lamp warning cleared, but I'm due my 600 mile service on Friday, so two birds.... And, $35 back for the retrofit kit I didn't need!
I'm terrible with photos, but here are a couple. I forgot to take any of the tail, but I will add later.
They are VERY bright, and the lens diffuses the light nicely, and the new surface mount LED's are not the directional elements of the past... These are very visable from the sides as well.
before...
These are the connectors...
after...
before...
after...
