My RT has 107K Miles on it and new PC880 battery installed last September. This morning, the bike started up as usual and when I got to work and parked after a 20mile ride, I noticed the clock had reset. Observing closer, I also noticed the RID was completely blank and no headlight. I fussed with the ignition key, moved the starter switch a few times but the display remained blank. I am pretty sure I'm dead in the water. I checked the fuses and I everything appears normal. Just for peace of mind, I will look up the fuses/relay library and check once more.
I have Platinum roadside if I am forced to but am wondering if you kind and knowledgeable folk have any troubleshooting ideas? I read some threads about the Hall Effect Sensor so maybe it's this?
While I check the obvious like battery, fuses, switches, do you have any ideas I should check. The clock reset to 0:00 got to 0:01 then even the clock went dead at that point.
Thank you
Sunny6
Thank you
Sunny6
