A while back on this thread I asked "where did my brake fluid go?" Now I've found the answer to my own question: the ABS module itself is leaking. I dug into the bike this afternoon to diagnose a low fluid level fault code, thinking I was going to be troubleshooting the level sensors and associated wiring. But just to be sure I opened the rear reservoir cap (the one that was empty before) and found the reservoir empty again.
The tray under the module (and under the battery, too) is damp with brake fluid. The four solid brake lines running into the top of the module are dry, as are the two reservoir vent hoses. The three sides of the module that I can see without removing it from the bike are also dry. This leaves only the bottom of the module and the back side next to the motronic.
How fixable is something like this? I'm not afraid to open up the module to work on it, but is this worth the effort? I'm pretty good with mechanical stuff but I don't have machine tools or machinist skills. I'm considering buying a used module, or just bypassing ABS and going with old fashioned manual brakes.
