C
cwoflyboy
I took my bike (97 RT1100) out a couple days ago. I had gone about 2 miles when it suddenly died. Acted like you had just hit the kill switch. The engine turns over fine but it never fires, all indicator lamps are normal. I checked fuel, fuel pump is coming on ok, battery voltage is ok, checked fuses, removed Motronic relay and cleaned the contacts all with negative results. I pulled a plug to see if I was getting fire, also no joy. I don't know if this is an ignition problem, bad kill switch or something else.
Any ideas/suggestions?
Thanks and take care.
Dale/cwoflyboy
Dale/cwoflyboy
