I smelled a burning plastic smell before my r1100s broke down on the side of the road. I traced the cause of the burning smell to the wires from the right handlebar kill switch that plug to the righthand side relay box as shown in photo.
The current symptoms of the bike are no start and no fuel prime. I checked first for fuses and only 1 was broken. A 4amp fuse for the rear light I think. Next I checked for the starter relay and I confirmed that it was not working. So that is probably the cause of the no start.
The no fuel prime issue is more difficult to diagnose. I swapped the horn and load relief relays with the fuel pump and motronic relay and I still had no fuel prime. I then jumped the fuel prime relay by inserting a wire to pin 3 and pin 5 and the fuel pump worked. I think that rules out any continuity issues with the fuel prime. I also swapped out the motronic unit with a spare one that is known to be good and still got no fuel prime. Am I correct in assuming that power from the battery stops somewhere between the ignition switch or the handlebar kill switch according to the electrical diagrams?
Have I ruled out all other possibilities?
