I tried to measure the clutch hub spline movement but the transmission input shaft kept moving. I solved this by tying off the input shaft with a piece of solid electrical wire.
1. Fish a wire around the input shaft and locate it over the spline.
2. Install the lower starter motor bolt.
3. Tighten up the wire around the bold.
4. Add a piece of tape to the pressure plate.
5. With the clutch disengaged move the clutch plate back and forth and mark the tape. Remove tape and measure. My movement was 3/16 inch.
Hope this helps others.
