03 R1150RT Clack-Clank in the Clutch in Houston
1. No need to disconnect tranny from engine.
2. First hand experience...those "few guys" are misinformed. 155,000km and yearly spline lubes of the starter removal/custom narrow needle type attests to its effectiveness.
Yes,I have heard of this type of greasing the splines but not in my book.I have lots of Moly 60 that takes a brush to apply and I am sparingly using it not to find it on my clutch.I also just pulled the trans and whole drive train back on guide pins to expose the splines for lubing.
hi guys, I had the rattle in my transmission on my 2000 r1100rt ,even having stripping and replaceing all bearings, clutch plate and input shaft from earlier model 6 years ago, lately removed gearbox to lube clutch and drive shaft splines noted clutch throw out bearing was worn ordered part and replaced it reassembled bike and hey presto rattle gone , now I havent ridden her since ,winter here in canada but happy, note my bike is an r1100rt cable clutch and throw out bearing which I belive is different from 6 speed r1150 rt but may have throw out bearing also ,hope this assists, once again merry christmas to all ,Jimmy:ca
Your 1100 has a mechanical operated clutch with cable to operate.It also has the 5 speed M97 Transmission.I had a 98 RT/P that I rebuild the transmission on.In my 2002 rt the 6 speed transmissions are different and much more robust.I do miss the cable operated clutch because now we have a hydraulic set up that is trouble prone.And thank you for your input.Merry Christmas to you.
Going to try to synch TB
Well, it may not solve my problems but a synch of TB and adjust of idle seems like a logical first step. Sent Chris Harris a video of my bike doing the clank-clank and to his ear he thinks it is out of sync so that is the cost effective first step and it seems like something I can do. Also, the shop had recently put in synth trans fluid so I may switch back to the Castrol non synth and see if that makes it happier. Just ordered a Carbtune Pro 2 from BeemerBoneYard so now I have a project for week after next. I wish I had a place to do serious work on the bike but workshop is filled with other hobbies and no room for a bike or a lift. Didn't know when I got an RT it would be both a mode of transportation and an erector set to play with.
Appreciate all the advice.
