Results 1 to 7 of 7
Thread: Stebel Magnum Installation
    JPHAN
    I'm replacing my stock horn with a Stebel Magnum. It's about twice the size of the stock horn. Mounted in the same location, the horn rubs on the brake line. Not good! I found another spot on the left side underneath the cruise control unit. But, I'm having a hard time trying to figure how to mount it. I believe I can use the existing horn relay and just plug it in and play? Any suggestions how to convert the Stebel to hook up to the BMW plug? I'm open to any comments or suggestions pro or con to my adventure!
    He Who Rests Rots! pfiedler's Avatar
    Apr 2009
    Boxford, MA
    Jeff,
    See the outstanding DIY Stebel Horn installation information posted by Semper Fi at the following:
    http://forums.bmwmoa.org/showthread.php?t=42834
    I'm going to do the same on my 08 K12GT shortly.
    Have fun and please ride safely!
    Peter
    Trickster
    For an inexpensive Stebel airhorn go to http://ridesafer.com
    I used SemperFi 's guide too, he made it easy
    JPHAN
    Thanks for your help guys. I think I can do it!
    Aug 2008
    Kingston, NH
    Take your time it is not bad at all.
    I think I did it in about 3 hours or so
    2009 G450X White
    IBA #35651
    Rogue Moderator
    JPHAN
    If Luis does it in 3 hours, I'll give myself 6 hours. If I finish anywhere in between, I'll be happy!
    Aug 2008
    Kingston, NH
    Quote Originally Posted by jphan View Post
    2009 G450X White
    IBA #35651
    Rogue Moderator
