Keep in mind that the thermostat on your machine is there to maintain a set temperature. If your machine is not overheating you have no problem. Now if your cooling system is compromised to the point that only using said additive is going to get you back into normal temp range then it may have some benefit. On the other hand you would gain more by simply repairing the compromised cooling system back to normal specs.
Bzzzt. Wrong. The cooling system is designed to operate with coolant or some sort of surfactant in it. Without the additives, using only water and nothing else, a properly operating cooling system might not cool sufficiently with the thermostat fully open if it is hot enough out and you are making high power demands of the engine.
Some BMW engines we know have surprisingly limited margins in the cooling systems if they are used hard in places such as where I live out in the Mojave Desert. K-75's, for example, run awfully hot on the center cylinder, hotter than is safe really and you will see failures of the middle cylinder out here on occasion. The cure is a three row K-100 radiator, though it looks kinda ugly. The 16V bikes have very little coolant in the heads compared to the previous generation of K-100s, compounded by a reduction in the size of the radiator core from three rows to two. They run hotter for the sake of emissions compliance, but this leaves little margin for extreme conditions. The wise desert K bike owner knows to find a three row radiator for that bike and maybe even an earlier, higher capacity coolant pump.
BBBBZZZZZZZZZZZZZZZZZZZZTTTTTTTTTTTT!
Please note that I specifically did not mention using only water in the post you quoted. I specifically did not mention anything other than the cooling system and the term additive. If you infer that means I suggest, recommend or specified using water only then I do suggest you look in the mirror for the source of the inference. No specification, mention nor implication was made regarding water only as a coolant by my post.
If suggesting that a properly maintained cooling system is a good idea offends you that is your problem, not mine.
I can read. That is not what you said or what you implied. You denegrated the necessity of additives and stated all you need were properly operating cooling system components. My reply to that is that in high temperature high load situations, that may not be enough. A properly working cooling system includes the coolant, mixed in the correct ratio with water.
