The bright green shaped ones.
NCS
What shape is "bright green"? I have been walking around Walmart for an hour and can't find them!
OK, I'll be the outlier here and say that if you're at all concerned about your hearing - and you should be - then only a custom molded solution will provide the best protection and the best of those is not cheap.
Used foam for years, always got the best I could, but NOTHING works as well as these http://www.earplugsonline.com/
