Okay, got a Cee Bailey windshield at one inch taller and three inches wider than stock. Do I automatically need aluminum supports or can I wait to see if the stock supports break first?
RT12, 09
I am going to go with a V-Stream. I noticed there were only 2 resources for off market bracket supports. Are there more options?
Hi, have a larger windshield on my RT. Replace the upper struts when one broke thousands of miles ago. Now one of the lower/front supports is broken. Will appreciate any wisdom on replacing this? Thanks, George
From a recent thread of mine (not good news, I'm afraid):
Long story short - plowing westward into some respectable headwinds (35+ MPH, or what SD natives call "a slight breeze"), a vehicle passed me close on my left, set up a sudden and disturbing vortex and my shield instantly collapsed near the headlight assembly.
I immediately lowered it and when I tried raising it again, it simulated the collapsing action once more. Luckily I was at a Sturgis exit, so off to Sturgis BMW for an evaluation.
Turns out the lower left bracket that helps to raise and lower the windshield on my R1200RT snapped in two. I had already replaced the two upper pieces of 'pot metal' after having snapped one of them - a chronic problem with the RT's - but hadn't given the lowers a second thought.
Unfortunately, the lower brackets are not modular like the upper ones are - a careful check of schematics revealed that these brackets and the motor/carriage assembly that operates our windshields are all one unit - to the tune of $350+ with labor.
Most, if not all, of the links on this thread are not working. Does anyone have a link for the website that sells the replacement struts for the windshield? Google's no help either.
Far out! Thanks!
Just picked up a pair of these upper struts from Beemer Boneyard and installed a ZTechnik Z2402 windshield with them. They seem well made and fit like a factory part.
I did notice though that the bottom flat side of both arms touches the black plastic on top of the nacelle in the full down position. I can see the side wind deflectors and my Migsel GPS mount flex just slightly as they push down on the plastic. Anyone else with these mounts notice this? Doesn't seem like it will become a long term issue, but I was slightly surprised that there was any contact. Perhaps that is the price you pay to have stronger struts that won't snap with the added air pressure generated by larger aftermarket shields.
