How to use a bike jack
Jforgo,
Isn't the oilpan the jackpoint on an R100RT? It seems real solid. I don't see what else I can use as a jack point.
Asaint
That puts a fair amount of weight on the pan and the same amount on the frame bolts. That is also less stable. I don't know that there is a designated jack point for our bikes; I haven't seen anything to indicate they expected them to be on a jack.
The one person I have known that used the type of jack you have fabricated and attached four small cradles similar to what you would see on a jack stand. They put them on the lower frame rails. Still a little shaky, but better.
Randy,
I use small 2x4's running the length of the bike. This means 100% of the weight is on the oilpan. The exhaust gets in the way of using the frame as a jackpoint.
Big question - do I continue to use the oilpan to jack up the bike or am I at risk for damaging something?
Asaint
Semper,
Interesting... I see there is a Harbor Freight about 20 miles from me. I wonder if they have this in stock there.
I think I can return the jack and then pay a difference of around $170. hmmmmm.
asaint
If you can swing it, get a driveon ramp.
Best thing i ever did.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=91764
I was just going to make the same suggestion!
Some time ago I went to Sears, bought a jack and then, once I saw what an unstable pia it was going to be, I returned it and drove over to HF and bought their cheapest lift.
That was three years ago and believe me, it's the best dollar I have ever spent on motorcycle tools, next to my service manuals. Some guys have griped about the HF lifts not being as well made as the US manufactured ones and thats probably true but mine works just fine. It's stable, rugged and it makes working on the bikes much less taxing. In fact, last time I checked, Ted Porter was using two or three of these as his shop lifts and they were holding up just fine.
The HF lifts usually sell for $300 with a coupon and at $100 more than that fancy jack, it's a huge bargain.
Click for full size!
<a href="http://s177.photobucket.com/albums/w238/kenwhitehawk/83%20R-100RS/?action=view&current=LATESTFULLFILE003-2.jpg" target="_blank"><img src="http://i177.photobucket.com/albums/w238/kenwhitehawk/83%20R-100RS/th_LATESTFULLFILE003-2.jpg" border="0" alt="Photobucket" ></a>
Repairs won't break your back, you can finally get the bike really clean and if youre short of garage space, just store your bike on the lift. It allows me to lift the bike up out of the "Scratch Zone" when I'm not riding it!
PS: You may be able to find a 20% off coupon here: http://forums.slickdeals.net/showthread.php?p=10074095#post10074095
Semper,
asaint
Let us know how it goes!
:thumb
Two ideas that have worked for me:
1) A 2x6 (or 8) under the centerstand. It's a pain, and perhaps a two person job, to get it up, but it leaves enough room to get the wheel out.
2) A couple of eyebolts in the rafters of your garage -- use tie down straps to lift the bike.
Yeah ... I wish I could get one of those bike lifts. For now I have a couple of jacks much like yours. At first I would just lift the bike sitting on the oil pan but didn't think that that was a good idea. In a previous post on this forum someone gave me the idea to build an adapter that would support the bike by the frame and make it sit more stable as well.
<a href="http://www.flickr.com/photos/24593939@N06/3661531282/" title="2009-02-18 BMW motorcycle lift 001x by kstoo, on Flickr"><img src="http://farm4.static.flickr.com/3377/3661531282_835a9008df_o.jpg" width="800" height="599" alt="2009-02-18 BMW motorcycle lift 001x" /></a>
More pictures and plans here.
On any airhead i've ever owned (all mid-to-late '70's vintage, not sure how much that matters), it was easy enough to remove the rear wheel by dropping the front wheel out, tilting the bike forward on the c-stand until the forks contacted a support object (milk crate or 4 gal paint bucket worked fine), and then pulling the rear wheel. Often changed both front and rear tires like that- no real issue.
i've since bought a H-F lift, which works fine as well. A strap across the seat holds the bike in place just fine. tilting forward or back is a theoretical concern, but i've yet to see it be a problem in practice. in fact, once the bike tips forward (weight of fairing will send it there), it is then more stable than it had been.
What part of your bike rests on the HF lift? I have one of the small HF motorcycle lifts - looks like it will hit the exhaust pipes.
I have this same Sears lift and used it once to change my rear tire. Even with help it was a bit spooky even with the bike strapped down. Next time, I "kneeled" the bike. Simple, stable. I did it to practice what I would have to do on the roadside. I will never use the lift again for a tire change.
ok,
I seriously like this technique. Not only for removing a tire in my garage, but also for the off chance I need to do this while on the road.
Thanks!~
asaint
Just be sure to secure the front axle to the c-stand with a couple of straps. I carry a pair of simple straps in my tank bag just in case...
I have an 83 R100RS , When on the centerstand it sits with the front wheel in the air. When you pull the rear wheel clear of the final drive splines the weight of the front wheel tilts the bike forward onto the front wheel. there is no need for any stands,jacking, or tie downs.
Does your bike have the saddlebag brackets, as shown above? That's the crux of the biscuit for my RT. First time I changed the rear tire, I removed the right side saddlebag bracket - a PITA. My Yamaha XS850 had a hinged rear fender that one could fold up, out of the way, allowing the wheel to be removed without messing with the hard luggage.
no, you leave the brackets on. Tilt the bike forward enough to give plenty ground clearance, drop the wheel DOWN, and then back past the rear hub. Exceedingly wide tires (stock is 4.25") may coomplicate things.
No, I have newer style integral cases, no need to remove the brackets.
