I purchased an auxiliary Denali brake light to put on my GSA. The brake light fits below the license plate using the lower license plate bolts. I need to run the wire from the auxiliary brake light up to the CanSmart I've installed under the rear seat. However, there is no gap or hole under the seat that will allow me to run the wires. I've attached a picture.
It looks like I will have to drill a pretty good-sized hole in the plastic through which I would run the wires. Definitely don't want to do this unless I have no alternative. If anyone has installed an auxiliary brake light on a recent model GS/GSA, how did you run the wires to the brake light?
Thanks, Don
Thanks, Don
