lee
Debbie's Servant
The new red wifi GS-911 has not been working to reset the service reminder on the liquid cooled R1200RS and R1200R when using a windows laptop.
It has worked when using a smart phone, but not a laptop.
Hexcode has finally found the problem and will have a fix soon.
For now they have a work-around that I tried on both of our 2016 R1200RS bikes and it worked.
The problem was only on the liquid cooled R1200RS and R1200R.
Below are two posts from Hexcode.
Francois said:Good news! We currently have an RS in our garage for testing, and it looks like we found the source of the problem. There are a number of other things that also need attention right now, but we should be able to release a solution for this issue swiftly.
Francois said:Even better news! We have a work-around that you can use to reset your service reminder right now with the existing GS-911 PC app.
The work-around requires that you use the "Choose custom date / mileage" function, and it should work for both the R1200R and R1200RS that have the XKOMBI53 instrument cluster.
The problem is that the XKOMBI53 cluster controller only accepts a service distance that differs from the bike's current odo value in increments of 100 km. Example: if your bike odo is currently at 10345 km, your service reminder distance can be set to 10445 km, 10545 km, 10645 km, etc. But, the cluster controller will not allow 10349 km or 10449 km or 10549 km, and also not 10355 km or 10455 km or 10555 km, etc. In other words, the last two digits of your service reminder distance must be exactly the same as the last two digits of your odo value, but only for km.
For those people working in miles, you'll have to do a conversion, but it may be easier to just set the GS-911 app to use km while you are resetting your service reminder.
We'll get this fixed in the app so that you won't see an error message for invalid values in future.
