DSXMachina
Member
I'm confused. I've seen the same tires mounted differently. I recently bought the Michelin 6 Road tires, front and rear. They are marked on the sidewall with an arrow and a "Front" on the front tire and an arrow and a "Rear" on the rear tire.
Each tire is marked in two places so that when one arrow is at the top it faces one direction, and the one at the bottom faces the opposite direction. I have to assume that I should follow the arrow which is in place at the top of the tire and is therefore not upside down. Same with the rear.
My problem is that this then results in one tread facing opposite the other! What I mean is that the grooves in the front tire converge as the tire rotates, the grooves in the rear tire diverge as the tire rotates. I have seen different photos with the tires not matching the other photos. The way I would do it is like how Michelin shows the tires in their ads, but I want to be sure that's right.
Why can't the tires just have an arrow with "Rotation" direction clearly marked on the sidewall like performance car tires do?
