I mounted the Cyclops LED auxiliary lights tonight. The Denali fork tube mounts worked perfectly too. The Cyclops lights come with a very nice wiring harness, in addition to the Skene automatic dimmer unit. Overall, wiring the lights is almost a plug-and play project. The connectors to the lights are impressive, when compared to most auxiliary lighting setups.
What is not apparent, is where I connect the Skene to the High Beam conductor on my 2015 R1200R LC. On Harley's, you can make the connection in the headlight fixture itself, or you can connect it closer to the battery on the High Beam conductor at the High/Low Beam handlebar switch.
Where is the best place to connect to the High Beam conductor? Unfortunately, I do not have a wiring diagram for this motorcycle.
Thanks - Peter Bucy
Thanks - Peter Bucy
