Where did the brake fluid go?
beeryboats
Hi All,
I consider myself a fairly good wrench, but my '01 R11RT has me a bit perplexed. After I got home from the national in TN I noticed the front brake was low of fluid. Thinking the the fron pads had worn I went out and bought new ones. But the old ones turned out to be fine. Lot's of life left, almost new. The dealer said I may have had an air bubble in the system somewhere. I have yet to take off the plastic to look for leaks at the antilock servo mess. I added fluid and will keep a sharp eye on the level. Has anyone else had this happen?
Check in the ABS reservoir under the tank - check for leaks around the ABS pump and along the various lines and connections.
I know on the iABS 1150 if you do a brake fluid change and top up the fluid before bedding the front brake pads you will see a minor to major drop in the brake fluid level in the ABS unit. Not sure if same would occur in the brake system on an 1100.
Pin Hole
I had a pin hole leak that would spray out the BF under pressure, but not noticable sitting in garage. Finally it gave out and I put on Speigler lines. Perhaps pumping the brakes in the garage will reveal your leak?
CB
