QuixotesHorse
Hi Everyone,
I'm having a problem where the bottom on some of the bleed screws (2 of 4) on my brake calipers are damp (1985 R80RT). It might be a bit hard to see but there is shininess on the cap's ring.
It's not a major leak; I've left the bike with the brake lever tied down for several days to observe but there are no drips, just dampness at the base of the screws. I'm looking for suggestions to rectify the situation. I've tried re-torquing, removing the screws and cleaning the mating surfaces best I can, and buying new bleeder screws but the dampness persists.
I've been thinking about taking one the bleed screws and filing off the threads (blue region in my poorly made diagram), then applying grinding paste to the bottom mating surface (red region) and gently rotating the smoothed screw inside the caliper to recondition surfaces akin to how we do valve lapping. Let me know if that sounds like a bad idea.
Thanks in advance!
Thanks in advance!
