Paul, I'm just trying to make it easier to check and fill my tires. The stems are short and very close to the spoke.
Wow. That is tight. Is that rubber collar an indicator that you’re running the tires tubeless? I’d replace either the entire valve stem, or the inner tube, with something that gives you a somewhat longer stem. Another 1/2” or so would make things easier. My Zefal bike pump recommendation would still help.
