I recently replaced the HES on my bike and believe I got the timing correct thanks to members on this forum. I then proceeded to adjust the valves and am now in the process of syncing the throttle bodies. I have done this procedure a couple of times previously using a homemade manometer but this time I am having problems . I have the left side adjuster turned all the way in and the right side adjuster all the way out and the fluid in the manometer is still substantially higher on the left side, which I assume means the left side is pulling more vacuum. This situation is present throughout the rpm range. Any ideas would be appreciated.
