mieczkow
Tom Mieczkowski
Comrades:
I am for the first time going to replace the fuel filters on my K75S. Getting off the filler cap etc. not a problem. Seeing the in-line cartridge filter (filter #1), and comprehending how to replace it - no problem.
However, in studying the parts fiche I have noticed the "second filter" (hence the two jakes) - the sort of baskety-type filter which appears to go on the distal end of the fuel pump assembly. Meaning, if I am interpreting the drawing correctly, that I need to remove the fuel pump in order to replace this second filter unit. Replacing the inline filter is a piece of cake. However, I have not ever taken the fuel pump out of my bike before, an act which seems necessary to replace filter #2. Editorially, I am forced to comment on filter #2, that it looks an awful lot like those "permanent filters" you buy for your Mr. Coffee machine so you don't use paper ones. But, I digress . . . .
Question:
1. How hard and or risky is it to pull out the fuel pump? Is there something (not having done this before) that I need to be aware of so I don't mess something up in extracting the fuel pump? Am I correct in assuming that the fuel pump must come out to replace this second filter?
2. Is it really necessary to replace this baskety/plastic cage type filter? How often? Same interval as the in-line cartrigde filter?
Any advice/enlightment is much appreciated!
Question:
