mattias_k1300
Is it possible to test if the ESA suspension is working without connecting the bike to a computer?
I have a 2009 k1300s with ESA 2.
is it enough to just turn ignition on and change the suspension ?
With the engine on but the engine NOT running, you may be able to hear the stepper motor change the damping settings on the front and rear shocks as you progress through the solo, solo with luggage, and rider with pillion and luggage settings.
Merry Christmas!
i thought the DAMPING settings front and rear only change through comfort, normal and sport modes. the spring PRELOAD on the rear shock only changes with solo, luggage and two up modes.
HO! HO! HO!
You are absolutely correct, sir. In my haste to respond I didn't have my thoughts correctly aligned (read: brain fart). I'm blaming Christmas Cheer.
time for more spiked eggnog!
