M
Manhattan Rider
Over the past 6 months and 10,000 miles, I have used the new Techlusion R259 TFI with very good results. I just returned from Glacier National Park and Yellowstone traveling 3600 miles at all elevations and in all types of weather. At 10,800 feet on Bear Tooth Pass, the bike ran great. The only negative so far is a loss of 2-3 MPG. My high mileage was around 50 mpg in the mountains with a low of 42 mpg at Interstate speeds, fully loaded two up.
My bike never surged until around 20,000 miles. The surging was so bad, the bike was no longer fun to ride. After several appointments at the dealer and my own failed attempts, I decided to fix the surge or sell the bike. My solution was disconnecting the 02-sensor and adding a Techlusion 83i. This eliminated the surge, however I had to operate the bike in open-loop (02-sensor disconnected). Since this product was new at the time, I documented my results for Paul Glaves (BMWMOA Tech Editor). Paul published this letter in the February 2002 BMW ON.
I then switched to the Techlusion TFI and the bike ran very well with no surging. I was able to use the TFI in closed-loop, however many owners could not. However, in open-loop, the TFI worked great. The new R259 TFI provides a connection to the 02-sensor ensuring it never provides the ECU with a signal to provide an overly lean mixture. So in closed-loop, my lean-fuel surge is totally eliminated.
Note: I am not employed or have ever received funding from Techlusion or Battley's for my endorsement. I do know the owner and inventor of the Techlusion products and have used Techlusion products for over 30,000 miles with great results. All three have eliminated my surging problem that could not be fixed by the dealer. Techlusion has provided me with a free R259 TFI to test on the road to help them determine their base setting. However, if it didn't work, I would be the first one to tell you.
