D
DS74BMW
I was just reading Karsten's "odometer issues" thread, as my trip odometer won't reset [sort of], the speedo needle will fluctuate wildly above 60 [then "settle down"], and the tach needle is not steady[200-300rpm wavering].
When I test rode, the speedo fluctuated above 30[would read 60-80, then "settle"], so the seller said he'd fix it. When I loaded it into the truck to bring home, he said he lubed the cables and opened the instruments up and cleaned dirt out, and it worked fine. After getting home, a trip down my street up to 30, worked fine [the trip meter wouldn't reset, though]. After putting tags on it, I went for a 40 mile trip. At some point, the trip meter reset itself to zero during this ride [and will not reset now], and counted properly, but the speedo above 60 would waver wildly[100-130], swing to zero, and then indicate properly. This happened 3 or 4 times in 40 miles.
I linked to Overseas Speedometer on Karsten's thread, and a note under BMW mfr said to disconnect the cable asap, as it was about to crash. I will do this, until I can resolve. Also, not all the instrument lights work, so I will try to resolve all this at same time.
I saw a site a week ago about disassembling these[R60/6] instruments for repair, but cannot find it again. Perhaps sending it to Overseas Speedo, but I like to do my own work as much as possible. I still do not have my ordered Clymer manual, so a site would help at the moment.
