Skene lights install issue
donng
Hello all perhaps someone here has experienced this and can offer a solution
I’ve installed the P3 lights but there’s an issue with one turn signal
As set up on the bike both the left and right LED will flash with brakes
but the right led will not flash with the right turn signal
The left bike turn signal and led works
The right side of the bike only the bike turn signal works but not the LED
Both LEDs do the normal Flickr and both LEDs work with the brake light
My bike is a 2005 BMW K1200S
Your Skene controller is not tapped into the correct wire or the controller has a malfunction. Those are the only two options.
Check your posi-tap to make sure you have the end with the sharp needle in it poking into the correct wire so that the turn signal wire is actually tapped and not just dented.
