R
rocketman
AFter getting my LT I realized just how weak the single disk on my 78 R100/7 was and started looking at options for improving it. Seems it boiled down to several options as list below: (the early airhead disk systems had the cable operated master cylinder, which was under the tank)
1. Replacing the whole front end to go to dual disks was not really cost effective, ($1000) or
2. Rebuilding just the one side to add a lower fork leg to take a second disk wasn't much cheaper or
3. change out the brake line from rubber to braided and/or
4. replace the handgrip with a later model grip with the master cylinder on the handlear ad get rid of the cable portion (since it stretches its not as positive as having the handle operate directly on the master).
The last two are best done at the same time or in stages but it would seem that they are the two things you can do that will give you the most bang for the buck.
What I have done so far on my 78 is replace the brake line with a steel braided one and let me tell you (which is the point of this post) it has made a VAST improvement in the airhead's brake response/feel. It is much more responsive and the feed back much improved. So I'd have to say that if you're looking for the easiest and most cost effective upgrade, I'd say get rid of that old rubber line (which for all I knew was the original 30 year old one, which is why I started looking at options before replacing just that or doing more).
I do think I will now get rid of the cable, which will cost me around $200 or so for the new/used handle and parts for a rebuild (since I won't know the age of the parts) before installing, and considering the improvement with the new hose, I expect that with the cable protion removed I should see equally positive results.
So anyway just thought I'd share, I know there are lots of folks with the old setup who might be interested in my results to date.
RM
RM
