Sena Device Manager problems
jgoertz
Member
Sena recently released version 4.0.4 of their device manager. Great! Except I can't get it installed on my Dell Computer, running Windows 10. Latest versions of Windows and Edge. Install goes until the last package -- USBCheck, then hangs. Without this module, the Device Manager can't find any device to update.
Any suggestions? So far, Sena hasn't come up with any thing that has worked.
I ran my v4.0.1 version of the Device Manager, it found the update, un-installed 4.0.1, installed 4.0.4, and relaunched. It then found and installed updates for my SMH10 and 20S. No issues on my Dell XPS 8930, Windows 10 Pro, v2004.
If you have not done so already, you might manually uninstall any old versions before launching the updated installer, without the device connected.
I had version 3.9 on both my units. They updated with out issue. Windows 10. Also device manager updated without issue.
Larry, I've uninstalled/re-installed 4.0.4 several times. Did you get a panel that starts "Power off...." and ends with the "CANCEL" block just before the install finished? (I tried to upload a screen show w/o success). If so, what action did you take? How did you get past that screen? Hitting that "CANCEL" button brought up a screen to install SENA drivers.
I haven't given up yet! (I also didn't have any luck updating my 50R w/the WiFi charger).
Thanks for the suggestions!
With the same installer package you downloaded from Sena, or have you pulled a fresh copy of the installer? This sounds like a mangled download.
Best,
DeVern
I didn't remember the screens exactly, so I un-installed the program and started over.
The Setup program created folders, shortcuts, etc, then this screen showed up
I plugged in my 20S (powered off). The screen changed to say my device was found and counted down a few seconds before closing. then a new "Welcome to the Device Driver Installation Wizard" window popped up.
After hitting Next, the driver was installed and then the Setup was complete.
Is it possible that on your computer the "Welcome to the Device Driver Installation Wizard" window is underneath the Installing window, waiting for you to click Next?
The only other thing I can think to do is try another USB cable, in case your 50R is not being recognized.
no issues updating the laptop to 4.0.4....and no issues connecting to and updating my 10U
but...4.0.4 would not recognize my 10S
hmmmm.
With the 50 series - You are way better off getting the adapter hooked up to the wifi ( done through the sena app)
That works great and means never having to deal with he device manager again. All updates are done automatically with no user input.
