Just installed a Scorpio SR-i300 alarm with perimeter sensor that is wired to an Eastern Beaver fuse panel.
The EB panel makes the install simple- both the "battery" (black wire) and "switched" (orange wire) can go to the panel.
The perimeter sensor for the alarm has adjustable sensitivity and plugs into the alarm box with its own wiring plug.
The remote can arm the system with or without the perimeter sensor being activated and can arm the alarm silently if you don't want audible notification.
The alarm connects to turn signals for visual notification.
The system can be purchased with an ignition immobilizer/anti hijack feature that I don't have. One EWS-like device is plenty for me.
Because my fuse panel takes its trigger from the rear accessory outlet that is controlled by the bike computer, it takes about 15 seconds to shut down after the ignition is turned off. This posed a minor problem when having the alarm "learn" the additional remote I purchased because putting the alarm into "learning mode" requires 3 on/off switchings in less than 6 seconds. I did a work around by temporarily installing a "push-pull" switch in the alarm switched (orange) wire and connecting it to the battery lead in the fuse panel. The switch jumper got removed after the remote was recognized by the alarm.
Alarm sold by Airtonix. Parts total about $190.
Everything fits under the passenger seat. Obvously many other installation variants are possible. An alarm like this really only 1 layer of the possible anti theft protections.
