I bought the Wunderlich replacement sight glass with the C-ring for my 1100 RS. I couldn't find the process for replacing the sight glass in my Clymer manual but watched a couple videos on removing the glass. From what I've seen, drill/punch through the plastic and gently try to pry it out with a screwdriver. Is this the best way to take it out? What are some of the things I could screw up and make things worse?
Also, is there a trick to reinstalling the new glass with the C-ring? Videos show to use a large socket to force the new glass in, but none of the videos had the glass with the ring. And again the most important question, what do I need to be sure to avoid when reinstalling?
Thanks in advance.
Thanks in advance.
