Morning!
Spent Sat. removing the failed dipped beam bulb, and replacing the bulb with the set from Cyclops.
I apparently failed to learn from the mistakes of others, and dropped the ring into the light.
I tried magnets (then learned the ring is non-ferrous), then tried a vacuum and moved on to replacing the main beams.
Each time I struggled, I paused and switched back to working on removing the headlights.
I finally found all the hidden screws, and the push pins/clips and removed the headlight entirely.
Knowing where everything belongs made re-assembly naturally much easier.
Ultimately, by Sun. I had the headlight out, got all 3 bulbs in and everything back together (save for the speakers/fairings).
Definitely a challenge (for the mind, and my finger tips) but if anyone has questions or gets stuck, I'm happy to lend my advice.
Will post pictures when I finish the fairings/speakers.
Andres
2016 R1200 RT, Marino Blue
Andres
