C
chipperdoo2
Just installed a new Progressive rear shock on my beloved K75S. Now when the shock is loaded or unloaded, such as hitting a bump, or, as little as putting it on or off the centerstand, I hear and feel a loud clunck. At first I thought it was due to the slop present just below the upper mount, (which Prog. says is normal and necessary). After taking it off I found 2-3 coils binding on the upper cover/cap, enough to take the finish off. Just wondering if anyone out there might have had a similar situation, and what if anything is the solution? Thanks
