Does anyone know how to remove the driveshaft from an R90S? I am having the bike painted and am stuck here.
Oh - did I say - stay out of the way.
I've painted several of those without taking the driveshaft out. If it doesn't need any repair or maintenance, just mask it off really well or put baggies over the ends and have at it.
Ride Safe
Rideoften
Once you've loosened the nut, remove the washer under it and replace the nut until it is flush with the top of the shaft. You can then use a press or puller without danger of the coupling flying off.
