Hi, I have a 75 R90/6. It is dual plugged with a dyna ignition. I rebuilt the carbs recently and did the choke circuit at the same time. If memory serves me correctly the needle was n the #3 position prior to the rebuild. When i put things back together i consulted the Bing rebuild guide and set them at position #2.
The bike starts fine with choke and will idle, without choke when it is warm. The problem is on transition from idle to higher RPM it kind of coughs and sputters, and nearly dies, before finally catching and taking off. If I leave the choke on it transitions fine. That leads me to believe the bike wants a richer mixture. My question is: Does the idea it wants a richer mixture sound reasonable? If so do you think a return to the #3 needle position would fix the problem?
thanks in advance for any ideas and advice!
John
John
